Ok i started the quad up today and went to ride it but once i hit half throttle it cuts out and stutters. Its like that in every gear do you think i need to clean my carb or maybe i have water in the gas?
quad not running good
2
Re: quad not running good on Thu Dec 17, 2009 6:02 am
When was the last time you rode it? What was the last thing you did before you put it away?
3
Re: quad not running good on Thu Dec 17, 2009 6:16 am
The carb need's cleaning is my guess. I would pay special attention to the pilot jet and the ventury tube or the emaultion tube what ever you want to call it.
4
Re: quad not running good on Thu Dec 17, 2009 7:22 am
Start with a spark plug it's cheap then look into the pilot and main being gummed up
5
Re: quad not running good on Thu Dec 17, 2009 7:32 am
Uh Um,
I think that there was a hill and some mud involved if memory serves me correctly!!!.....
6
Re: quad not running good on Thu Dec 17, 2009 9:03 am
Definitely a carb issue, change out the gas and clean the carb, may be pilot jet but I would aim for the main jet.
most of the time if its pilot jet it will be idle, if it had to have the choke to run I would suspect the pilot but upper end would probably be pilot
7
Re: quad not running good on Thu Dec 17, 2009 2:05 pm
lol bryan yea it had a hill and mud involved. Ok thanks everyone for the help ill keep ya posted.
Similar topics
