Got a 94 kaw 250 quad have a few questions????
Its a 94 kawsaki 250 quad is all i know 5 speed maybe reverse could be a mojave i dont really know
my main question is it 2 or 4 stroke?
let me know if you can help
do you have any pictures of it?
If it looks like this it would be a Mojave and the 250 Mojave I believe was a four stroke engine.
Yeah not that nice lol for 200 bucks its an ok looking wheeler
so its a 94 kaw mojave 250 does anyone know anything about them not starting unless u push start it and after it warms up you can kickstart it just fine?
if u need more info let me know
Probably low compression, I had a dirtbike I rode for years that did the same thing. If you plan to ride it much you might go ahead and rebuild it now to avoid further problems.
its got good compression has spark and is getting gas how do you check the timing on the 250 dohc motor?
anyone know
not sure myself
does anyone know what the compression should be?
If I remember right it has to be at least 100
I would just limp it along till it gets too cold to ride, then pull the engine off and rebuild it over the winter, the kits on ebay with the jug, gaskets, piston, pins, etc etc etc are 230 bucks which is nottttt bad for a kit with the jug included. That will also allow you to check the frame for cracks or damages, paint it, replace or paint other parts and make any other repairs to have a LIKE NEW quad next spring. I am going to start a project in the next month or so and I will keep you all posted on that :-)
If you need any help rebuilding it im sure we have members that live nearby that would be glad to turn a wrench or drink your beer while giving you advice lol
http://cgi.ebay.com/ebaymotors/Kawasaki-KSF-250-Mojave-Engine-Motor-Top-Rebuild-Kit-_W0QQcmdZViewItemQQhashZitem334ab11d64QQitemZ220296453476QQptZMotorsQ5fATVQ5fPartsQ5fAccessories
