Mokan Riders Offroad Club
Would you like to react to this message? Create an account in a few clicks or log in to continue.
Can anyone tell me where the fuel air screw is on a 06 yzf 450?
4 posters
Mikey Mike
Shocked I can't believe i can't find it.......
http://miketraish@yahoo.com
from what I can read it is inside the float bowl for some reason but not sure why.
They make a remote one that you drill through the float bowl and it adjusts like the idle though, you might keep checking but that is what I found on some forums online.
BBIII
BBIII
Ya on the newer 06 FCR carbs they made it non adjutable fuel screw, like said adove u take the bowl off and drill it out and replace the fuel screw with one from a 04-05 carb and your done.
http://sandslingers.com/
Mikey Mike
Thanks guys. I guess that's why I couldn't find it. Dumb place to put a fuel screw.
Mikey Mike
The fuel air mixture screw is on the front side of the carburator. Very odd place to put it. and it is way up in there so its very hard to reach.
so you did find an external one?
Mikey Mike
yes. It is on the front side of the carburator on the bottom. Almost impossible to find. To get to it you would need to use a screw driver with a bend at the top.
Glad to hear that you found it. Probably one of those special part number screw drivers or something too.
http://www.myspace.com/bryanweirich
Mikey Mike
Of course you need a special screw driver, they do this shat on purpose so they can make money. Most people just take it to the shop and pay $100 or more dollars to have the techs do it for them.
