z400 runs for 3 minutes then dies will not restart
hello everybody I picked up a 2004 ltz400 over the weekend traded my sportsman 500 for it evenup ran good for test ride.
powerwashed it and bam run for 2 minutes and die would not restart at all,let it set for 5 minutes start rightup no problems.not fixed
after the trade foundout temp bulb was mia so took neutral light bulb and put in temp outlet for light.fixed
later noticed fan not working at all (about this time im thinking wow problems are starting to addup).
foundout the main ground on the battery was broken and not hookedup to the battery fixed that but could not keep it running kept dieing after 1or2 minutes.
took front plastics off and discovered the spark plug hole full of water blew that out and got it dry.put it back together bam runs perfect.
fan works-it stays running
I cant believe water in the plug hole would cause it to die like that!and not restart for 5 minutes of setting.
now I got 2 brute 750s and 1 ltz400 so I can keepup with you guys on sport atvs (look out im ready to ride this thing)
just thought I would share this information
from killer454
Sweet!
Sounds awesome. Glad you got it going.
President, MOKAN RIDERS OFFROAD CLUB
Sweetness! My cat is the same thing- zuk in arctic clothing... They are great for jumping and make most crap landings pretty smooth! You will love it
dielectric grease the plug between the wire and the plug will fix the problem that's what I had to do on my brute so the water don't short it out when I go deep
Sweet
