Number of posts : 327 Age : 39 Location : lawson,mo/ recently moved to polo,mo Job/Hobbies : all around construction does it all / hunting, fishing, riding Equipment : 95 warrior 350, 02 240 Blaster Registration date : 2009-04-21
This is the start of it. Taking a old go cart frame and stretching it to fit adults. Then adding blaster a arms, banshee shocks on front, blaster swing arm and axle on back. And of course adding a roll cage to the frame. Because I'm sure I'll need it.lol. right now it has a 8hp engine but goingto get a bigger engine. I found three 440 snowmobile engines, but I would like a engine with a manual transmission. but the snowmobile engines are cheap and not much wiring so I might go that route.
