Curado came down, we pulled the plug and cleaned it then we opened the airbox. Drained oil that was in there. It was a lot of oil! We gathered that the piston ring has broken and is letting oil bypass the piston into the hose coming from near the top of the cylinder, getting sucked up by the carburetor. Then it is expelled by the exhaust. Does this sound right to you mechanic types or not? Please advise!!! I think that I need a CLYMER MANUAL so I can take it apart and fix it. Money is kinda tight for everyone, cant really afford a shop unless it would be real reasonable. HELP YOU ALL!!
Rickey
Rickey
