Curious if anyone has one
1 Curious if anyone has one on Fri Apr 09, 2010 12:21 pm
I have my stock tires mounted on my renegade rims i need un mounted, then i need to un mount the bald tires off the arctic cat, then mount the renegade tires on it, anyone have a tire changer to make this easy ?
2 Re: Curious if anyone has one on Fri Apr 09, 2010 1:51 pm
Might try Top1....If he still has his, I belive it is all the power that you can put into it...LOL
3 Re: Curious if anyone has one on Fri Apr 09, 2010 2:58 pm
anything can be better than what i have (2 big screwdrivers and a small sledge hammer, lol
4 Re: Curious if anyone has one on Fri Apr 09, 2010 9:55 pm
Yea I have one JJ just let me know when you wanna come buy
I have a bead breaker but still use wide pry bars its pretty easy
5 Re: Curious if anyone has one on Sat Apr 10, 2010 12:05 am
yea, i was going to use my uncle tire machine, but, it requires the rim to have a hole in the center, mine don't, they are solid, i am going to head to amaco in the morning, if they can not, then i will give you a call, thanks
6 Re: Curious if anyone has one on Sat Apr 10, 2010 11:39 pm
i use tire bars to to remove the tires but to break the beads down i jack up the truck slip the edge of the tire under the tire of the truck then let the truck down on the tire to break the beads down.
7 Re: Curious if anyone has one on Sun Apr 11, 2010 8:33 am
Yeah I use pry bars too, not real fun on truck tires but works ok on quad tires
8 Re: Curious if anyone has one on Sun Apr 11, 2010 9:00 pm
well this weekend I had to mount and unmount tires on my father in laws fourtrax so I can take it to perry lake it was a pain but got er done though
9 Re: Curious if anyone has one on Sun Apr 11, 2010 10:19 pm
Well...... i had 8 dismounts and 4 mounts, did not think to ask how much and said just do it...........................charged me $78.00............i was like stunned, paid him told him do not worry about return work
10 Re: Curious if anyone has one on Mon Apr 12, 2010 5:24 am
Heck, at an hours worth of labor rate.....that doesn't sound all that bad though!
11 Re: Curious if anyone has one on Mon Apr 12, 2010 5:33 am
I have never and will never have a shop do atv tires for me just for that reason. Honestly how hard is it when the machine is doing all the work. Last time i needed tires changed that were junk I just cut them off. Getting the nes one on aren't hard. Definitley not $78 worth!!! Shops are worthless.
12 Re: Curious if anyone has one on Mon Apr 12, 2010 8:09 am
Thats about what they charge. When I didn't do my own tires they charged about 20-30 per rim.
I have since bought three tire spoons and the harbor freight bead breaker and they paid for themselves the first time I used them.
