2006 Transmission Gear Selecter
1 2006 Transmission Gear Selecter on Sat Mar 20, 2010 2:12 pm
Guys and Gals, I need some technical advice. I have a Grizzly that gives my wife a very difficult time in shifting in and out of gear. What could the problem be? Another question I have is does anyone know if there is a seperate reservoir for the transmission? I have been all over the owners manual and all I found was that there was cv belt plug, located below the crank case. Pulled that and no water came out so good to go there. Help ......
Rickey
2 Re: 2006 Transmission Gear Selecter on Sat Mar 20, 2010 7:39 pm
is it a manual or auto? Sometimes if the engine is idling too high it will be hard to shift a manual into gear or if the clutch is not fully engaged.
3 Re: 2006 Transmission Gear Selecter on Sat Mar 20, 2010 8:04 pm
Thats kinda what I was thinkin Geoff My vinson is like that if my choke is on making it idle high
4 Re: 2006 Transmission Gear Selecter on Sun Mar 21, 2010 4:06 am
yeah my dad has an auto clutch manual quad and to put it in high or low is almost impossible with the choke on and sometimes it will idle up a bit and its VERY hard to get into gear
5 Re: 2006 Transmission Gear Selecter on Sun Mar 21, 2010 9:36 am
Heres a link to Grizzly Central. com check it out it might be helpful.
http://www.grizzlycentral.com/forum/grizzly-engine-transmission/13452-hard-shifting.html
6 Re: 2006 Transmission Gear Selecter on Mon Mar 22, 2010 11:52 pm
ILL have her try to shift in and out of gear with the choke off and see what happens. Thanks for the advice gentleman.
Rickey
7 Re: 2006 Transmission Gear Selecter on Sun Apr 11, 2010 10:39 am
Hey all it really Worked AWESOME today. Had to move wifes atv so I could get mine out to go riding and turning the choke off made Melissa's Grizzly so easy to put the gear selector into gear. THANK YOU ALL FOR YOUR HELP!!
Rickey
8 Re: 2006 Transmission Gear Selecter on Sun Apr 11, 2010 1:48 pm
Glad you got it figured out Rickey!
